The van started okay, let it warm up for a couple of minutes. Then put it in reverse backed up a few feet then it shut off. When I went to restart it I had a no crank no start problem. Checked the battery it was okay, but tried a jump start anyway but nothing. Checked the fuses and relays even swapped out the relay just in case still nothing. Checked that the starter is getting power and it is gave it a few taps and still nothing. If you put a jumper wire across pins 30 and 87 the starter will work but engine will not start and that is with the key held in the full start position. If the key is in full start position with the lights on the lights do not dim at all. While it was running the only thing done was the MAP sensor was replaced and the van was started and run numerous times since then. I know some basics about cars but if suggestions of things to try could be put in very basic and detailed directions I would really appreciate it. Thanks
Jul 7, 2018 at 9:55 AM
