Engine will not crank, no check engine light on
303,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
SIYABULELA NTSOKO
  • 5 POSTS
I just took my gearbox off and do some work on it, then when after put back everything there is no check engine light on the dash, only only oil and battery lights on when the key is "on" position. what might be the problem.
Feb 20, 2021 at 2:41 PM
  • 110,248 POSTS
If the vehicle isn't starting, the first thing I suggest is to check to see if there are diagnostic trouble codes stored in the computer. This vehicle has an OBD1 system and doesn't require a scan tool to retrieve codes. Follow this link:
https://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995
Do that and let me know the results.
Take care and God Bless,
Feb 21, 2021 at 9:26 AM
