No air is blowing from vents (hear a noise in the rear of the car)
2009 MERCEDES BENZ ML350
76,232 MILES • 3.5L • 4WD • AUTOMATIC
SHAWNTIAC
The heat has been working fine. The car was washed yesterday morning and during the afternoon the heat was working. I attempted to drive vehicle later yesterday evening and discovered the heat is not blowing any air out at all. Due to the cold temperatures is it possible something be frozen.
Jan 5, 2014 at 9:02 PM
  • 110,240 POSTS
Can you hear the blower motor running?
Jan 5, 2014 at 10:45 PM
SHAWNTIAC
Jacobandnikolas, The heat is turned on a hear a noise from the rear of the vehicle. I am assuming the blower is trying to run. I never heard that noise. No air is blowing out not even the AC.
Jan 5, 2014 at 11:22 PM
  • 110,240 POSTS
Can you describe the noise?
Jan 5, 2014 at 11:36 PM
SHAWNTIAC
It sounds quiet humming sound.
Jan 5, 2014 at 11:42 PM
  • 110,240 POSTS
I have to be honest, to the best of my knowledge, the blower motor is under the dash and not the rear. The sound you described can be many things. It could be a blower motor that is stuck and not spinning or it could even be the fuel pump you are hearing if it is in the rear.
Jan 5, 2014 at 11:52 PM
SHAWNTIAC
Okay, thank you!
Jan 6, 2014 at 12:01 AM
