Service engine indicator light On
2003 NISSAN XTERRA
AGONZA1
The 'Service Engine' indicator light came On. I noticed that when accelerating the car mainly after changing gear, it goes slow for a moment then speed up, I also noticed a minor noise in the exhaust pipe when accelerating. I have tried to located the fuel filter to replace it just in case, but I can't find the filter location.
Can someone provide me any clue that help with this issue.K miles
Jan 2, 2010 at 10:17 AM
Attached below is a picture of the fuel; filter location. If the check engine light is on, you should scan it for trouble codes to see what the computer has found fault with, this will help pinpoint the issue instead of just throwing parts at it This guide may help you figure it out https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
https://images.2carpros.com/forum/automotive_pictures/12900_fuelfilternissan_1.gif
Jan 3, 2010 at 5:36 PM
