Brake lights stay on
SMCLARK555
When the headlights are turned on, the brake lights come on (even when the brakes are not engaged). When the headlights are off, the lights work like they are supposed to.
Aug 20, 2010 at 5:59 AM
MERLIN2021
  • 17,250 POSTS
Headlamp operation is controlled by the BCM (body control module) based on inputs from the combination switch (lighting switch). When the lighting switch is placed in the 2ND position, the BCM receives an input signal requesting the headlamps (and tail lamps) illuminate. The BCM sends a signal, via the CAN communication lines, to the IPDM E/R (intelligent power distribution module engine room) requesting the headlamps be turned ON. The CPU (central processing unit) located in the IPDM E/R controls ground for the headlamp high and headlamp low relay coils. These relays direct power to the respective headlamps, which then illuminate.
Pretty complex for a headlamp circuit... this means you probably need the Nissan scan tool to read the B and U codes to figure out if a new BCM or other part is needed.
Aug 20, 2010 at 6:07 AM
DON SAMSONITE
Thank you for this post I had this problem and had to replace the BCM cost me $334.00 all fixed I love this site.
Nov 11, 2019 at 4:31 AM
SUZ325XI
The brake lights on my 2007 Nissan Versa come on and stay on when I turn on my headlights. When headlights are off, brake lights work normally. any idea what's causing this?
Nov 11, 2019 at 4:31 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Check tail light bulbs for a wrong installed bulb
Or a bad bulb socket
also inspect wiring harness at the rear
