Cluster Instrument panel
NISSAN SENTRA
SHERILIN
Nissan sentra 2004 1.8s with only 15000 miles. My insrtument panel was off but I was able to drive home. The next day I wanted to take the car to the dealer and the car did not start at all. I had jump start and was able to get to nissan service. I been told that the reason might be the instrument cluster. They will replace it and check if this was the problem. Do you have any ideas what might be the problem? I have this car for three years with regural maintenance and oil change. Thank You.
Feb 20, 2007 at 6:57 PM
BHUGG
  • CERTIFIED EXPERT
  • 157 POSTS
check all fuses. some cars have 2 fuse boxes so check ALL fuses in each panel. Check in your owners manual for fuse locations.
Feb 22, 2007 at 1:38 AM
