I recently replaced the serpentine belt on my 99. Take the right front wheel/tire assembly off and remove the plastic wheel well liner. You should be able to see all your pulleys. On the lower right side of the engine, behind one of the pulleys, there is a 10mm tension adjuster for one of the pulleys. Loosen this adjuster to remove the smaller belt. Assembly is just the opposite.
SPONSORED LINKS
Saturday, August 18th, 2007 AT 1:02 AM
