2000 Nissan Sentra Engine starts
JON828
  • 2000 NISSAN SENTRA
  • 4 CYL
  • 92,751 MILES
The engine starts then stall when you press on the gas. Even stalls after you let it idle. Believe it has something to do with the idle control valve motor. How do I know if it is the idle control valve motor
Saturday, April 24th, 2010 AT 3:02 AM
  • 31,937 POSTS
Hi there,
If you get a scan done you may get a fault code, failing this a run on a live data scanner will shot the stepper motor positions during idle.
Mark (mhpautos)
Saturday, April 24th, 2010 AT 3:22 AM
