Will a blown head gasket keep this car from cranking or running and if so, how much should it cost to repair?
Wednesday, January 30th, 2008 AT 8:31 PM
BLACKOP555
MECHANIC
A blown head gasket wont cause the vehicle to crank, a bad intake manifold gasket could if you have a wet type manifold.
But a blown headgasket would prevent a car from running right or even running, perform a compression test on each cylinder to find out, lowest should be no more then 25% less then the highest cylinder.
SPONSORED LINKS
Wednesday, January 30th, 2008 AT 8:39 PM
MECHANIC
Check the cylinders for coolant if its a headgasket it will show in this model sentra-BTDT and don't forget to have the head resurface.
