How do you change the alternator belt and what does it look like
Tuesday, September 1st, 2009 AT 3:52 PM
JEEPFAN
MECHANIC
To change the belt youll need to loosen the bolts on the alternator and adjust the tightening screw enough to get the belt on however you will also need to remove the a/c belt and water pump belt. The alternator belt should be a grooved belt. The others are v belts
