1996 Nissan Sentra spark plugs
CRICHE
  • 1996 NISSAN SENTRA
Engine Mechanical problem
1996 Nissan Sentra 4 cyl Front Wheel Drive Automatic
car wont start, turns over only and when I pulled #4 spark plug it was covered with motor oil
Sunday, December 28th, 2008 AT 4:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It sounds like you may have a leaking valve cover gasket. Also, sometimes the plastic valve cover used warps a little from the heat which can make the gasket stop fitting correctly. This will cause oil to leak out. Not all models use the plastic valve cover.
Hope this helps.
Thanks for using 2carpros. Com!
Sunday, December 28th, 2008 AT 4:36 PM
