Does a blown timing belt mean that the engine is gone?
Wednesday, April 7th, 2010 AT 5:49 PM
TOOOMANYTOYS
MECHANIC
This is an interfence engine. Meaning if the timing belt breaks and can cause the piston to hit the valves. You would have to do a compression test to detemine if you have damaged the engine internally.
