1994 Nissan Sentra
FQUEVEDO
  • 1994 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 195,000 MILES
My car has a hard time climbing a hill and it hesitates when the gas is low. Is this a sign of fuel pump problem?
Friday, March 12th, 2010 AT 3:18 AM
Lack of acceleration, chugging, hesitating, bogging etc. Could be caused by one of the following below.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Friday, March 12th, 2010 AT 3:46 AM
