HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Sentra
Fuel System
Fuel Pump
Location
SPONSORED LINKS
1989 Nissan Sentra fuel pump
TMWHALEN
MEMBER
1989 NISSAN SENTRA
Electrical problem
1989 Nissan Sentra 4 cyl Two Wheel Drive Manual
where is fuel pump relay located on 1989 nissan sentra? Also I only have 9 volts going to the fuel pump what can I check?
Monday, October 4th, 2010 AT 3:00 PM
DOCFIXIT
MECHANIC
Under left side dash see diagram
Should haave full battery voltage at pump check pump ground
SPONSORED LINKS
Monday, October 4th, 2010 AT 3:18 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Location Content
1995 Nissan Sentra Looking For Suggestions
Here Is My Question My Car Drives Fine For The Most Part. Lately Some Times When I Drive And I'm Like At A Light, Stop Sign, Anything That...
Asked by
Rafael27
1 ANSWER
1995
NISSAN SENTRA
Where To Find The Fuel Pump Relay
No Power Going To The Fuel Pump. Fuse Is Good. Found A Relay Box In The Engine Compartment But Does Not Contain A Fuel Pump Relay.
Asked by
Elden
3 IMAGES
1998
NISSAN SENTRA
Can Be A Bad Pump? I Need To Replace It Again?
Hi! I Replaced My Fuel Pump. After I Replaced It The Check Engine Light Came On The Codes That It Showed Were Po181 And Po183. So, I...
Asked by
ipasal083
5 IMAGES
2006
NISSAN SENTRA
1994 Nissan Sentra Fuel Pressure Loss/ Start Problem
Hi, I Have A 1994 Nissan Sentra Le With A 1.6 Ga16de Engine With 103,500 Miles. I Began To Have A Starting Problem Some Time Ago, And...
Asked by
ChristopherEllington
1 ANSWER
1994
NISSAN SENTRA
My Car Doesn't Start. What Could It Be? Changed...
My Car Doesn't Start. What Could It Be? Changed Distributer, Cap, Rotor Checked Fuel Pump Checked Fuse
Asked by
cisco9595
1997
NISSAN SENTRA
VIEW MORE
SPONSORED LINKS
Fuel Pump Replacement
How to fix an engine that wont start
Engine Not Starting
Online car repair manuals
