Electrical problem
1989 Nissan Sentra 4 cyl Automatic
put battery around the wrong way when I put terminals on it sparked now I cant start it help
Thursday, October 30th, 2008 AT 1:30 AM
MECHANIC
HI there,
Check all the fuses and fusible links, there should be a main ECU fuse, make sure that is OK, but you do run the risk of cooking the ECU when this happens, but hopefully it will be a fuse problem.
