1997 Nissan Quest heater
1997 NISSAN QUEST
176,000 MILES • 6 CYL • 2WD • AUTOMATIC
WHITACRE
the van runs cold it does'nt reach normal running temp. the heater blows luke warm air i think the thermastat is not opening all the way because the top hose of the radiator is staying hard any ideas of what might be wrong?
Jan 16, 2009 at 7:14 AM
EUGENE123
  • 273 POSTS
i would start with the thermostat, but before you do that check your coolant level to make sure its full if so then check thermostat if this checks out post back and i will help you with this problem
Mar 25, 2009 at 11:52 AM
