Warning Chime?
GARYWHITTAKER
I have a 98 Pathfinder. The chime to indicate that light have been left on no longer works. Any ideas? The dealer thinks it is $700 module.
Is there an aftermarket fix. I heard there is a chime that fits into the fuse panel...
Thanks in advance
Sep 29, 2006 at 8:31 AM
EXTREMIST
  • 7 POSTS
You'll find the chime module under the dash, it can be unplugged to stop the chime, yours has probably died. Try replacing it. Here is the location in the images below. there is no aftermarket fix for this fyi.
Oct 4, 2006 at 2:32 AM
FUSECON
I have the same problem. No warning chime for lights on, key in ignition, etc.
Everything points to the Smart Entrance Control Unit (I guess that is the $700 module). However, when I took it to the dealer they pointed to behind the dash to fix the problem (investigate more) and that would be 2 hours of labor.
If there is a little buzzer/chime back there outside of the SECU it isn't well documented in the manual.
-dan
Dec 23, 2006 at 6:04 AM
FUSECON
[quote:578c3fc2c2="fusecon"]
[/quote:578c3fc2c2]
The shop manual for Nissan Pathfinder 1998, page EL-252, states the following:
Warning Chime (located in Smart entrance control unit).
Dec 23, 2006 at 6:11 AM
