1998 Nissan Pathfinder hard to start
BRIZIELINS
  • 1998 NISSAN PATHFINDER
Engine Performance problem
1998 Nissan Pathfinder 6 cyl Two Wheel Drive Automatic
Hi my sons pathfinder has starting probs, runs great when started. He uses starting fluid to start. Problem started when he was 2 qts low oil filled everything ok. One week later prob back changed oil pressure sender no help, changed oil and filter and sender again no help. Could it be fuel pressure?How is fuel pressure tested?
Thursday, June 24th, 2010 AT 5:17 PM
Check fuel pressure at the fuel filter Tee-in between the fuel filter and the engine side
Fuel pressure should be 34psi when engine is idling and w/o vacuum on the pressure regulator 43psi
Friday, June 25th, 2010 AT 4:46 AM
