1986 Nissan Sunny High CO
NISSAN
PARAGON48
Sir, I have Nissan Sunny 1.0 LX, 1986 with E10 type engine and have done 150,000 KM. It was ok with traditional spark plugs, and the Co was within normal range. The trouble started when I put BOSCH Platinum 2 spark plugs. The plugs become black with carbon, before it was brown. On analyser test, it is ok at idle state, but the Co jumps to above 12 when RPM increases, and the fuel consumption is also incresased. One said it is the Platinum 2 spark pluge, as it needs more air to burn the more fuel which cannot be provided by the original intake.
What is your opinion.
Mar 4, 2007 at 11:24 PM
  • 75,988 POSTS
Use the OEM spark plugs and comeback and we'll discuss the partly burn gases call CO-carbon monoxide.
Could be an oxygen sensor or the Cat
The problem here is you're burning fuel with less O2.
Mar 5, 2007 at 7:12 AM
PARAGON48
Now I have traditonal single pin spark plugs, the smoke has increased, with certainly more fuel.
what should I do now.
Nissan Sunny
Mar 7, 2007 at 10:32 PM
  • 75,988 POSTS
[quote:3d218ec18e="paragon48"]Now I have traditonal single pin spark plugs, the smoke has increased, with certainly more fuel.
Nissan Sunny[/quote:3d218ec18e]
Check the Coolant temperature and Oxygen sensors/injectors
Mar 8, 2007 at 12:06 AM
PARAGON48
The coolant remains at cold stage, other function of carburator is ok, but I still got small amount of smoke at spark plugs.
Mar 11, 2007 at 6:31 PM
Suggested Repair
Return to OEM spark plugs and check the coolant temperature sensor, oxygen sensor, and injectors. A coolant gauge that stays cold can keep the mixture rich, causing high CO, black plugs, smoke, and higher fuel use.
Conversation Summary
A 1986 Nissan Sunny with an E10 engine ran normally on traditional plugs, but Bosch Platinum plugs fouled black and CO rose above 12 as RPM increased, with higher fuel use. After returning to single-pin plugs, smoke and fuel use remained high and the coolant stayed in the cold range. The expert advised OEM plugs and checking the coolant temperature sensor, oxygen sensor, and injectors because the engine is burning fuel with too little oxygen.
