Mine is a 1998 Nissan Maxima GLE with 112K miles. Recently I changed my two rear wheel tires & went for rotation. After that, there is a screeching noise from the driver side rear wheel. It is worst when on the rough & bumpy roads. But when the brake is pressed & the vehicle is completely stopped & moved, the noise goes off. Again it comes after sometime. What is the problem?Should I go in for the rear brake pad change or is it something else?Can you please give me an estimate for it also? Thanks in advance
SPONSORED LINKS
Thursday, August 16th, 2007 AT 2:12 PM
