Hi 02 maxima,
P0011 and P0021 are related to the Intake Valve Timing (IVT) Bank 1 and 2 respectively.
Malfunction is detected when there is a gap between angle of target and phase control angle degree. Possible causes are:
"Â IVT control solenoid valve circuit open or shorted.
"Â Defective IVT control solenoid valve.
"Â Defective Crankshaft Position (CKP) sensor (POS).
"Â Defective Camshaft Position (CMP) sensor (PHASE).
"Â Debris accumulated on signal pick-up portion of camshaft.
They are not directly related to the spark plugs replacement and it is best to get them checked and rectified as it would affect the performance and fuel consumption.
During replacement of the spark plugs, some wireharness could have been unplugged and not reconnected securely. Recheck all wire harness connectors around the cylinderheads.
SPONSORED LINKS
Sunday, September 19th, 2010 AT 1:19 PM
