2000 Nissan Maxima Engine won't go into Overdrive
MAPBRD
  • 2000 NISSAN MAXIMA
  • 6 CYL
  • 166,003 MILES
I've change the airflow meter, which was bad. But, my car at highway speeds won't shift into Overdrive. Rpm stays high. Its going through gas. Overall the cars has always run well and have never had a transmission problem. Does the transmission has to be reset(recoded) like I did when I installed the new airflow meter?
Sunday, January 10th, 2010 AT 9:13 AM
92 MAX
  • 36 POSTS
Hi maprd
No transmission should not need a reset even if battery removed.
Was a plug knocked of the engine, say throttle position sensor where the throttle cable connects.
Regards Don
Wednesday, January 13th, 2010 AT 4:54 PM
