2000 Nissan Maxima Engine light
82,750 MILES • 6 CYL • 2WD • AUTOMATIC
ORACLEPANDIT
The other day all of a sudden I started seeing the Engine Light on my car panel. One of my friend suggested me remove the Negative terminal of the battery for 20 mins and put it back and check if it comes back again when the engine is started. The light didn't come this time, but the car was behaving very strange. The engine used to idle for a couple of minutes and used to shut down. I restarted it and this happened a few times. After this the engine started idiling but there seemed to be lack of power in the engines. No matter I pushed the pedals, the vehicle wasn't moving forward or if it moved it moved very slowly. I clearly felt the engine wasn't able to power the wheels. After a few trails runs, it started moving but the acceleration of the is very slow. I'm not sure what could be the problem here as I'm not very good with Cars.
Nov 8, 2008 at 1:01 PM
  • 31,937 POSTS
HI there,
The light is an indication that the ECU has detected and stored a fault code for the engine management system, you will have to get a scan done to read this code, its unique number will be the code to what item has been detected as faulty or out of range, get the scan done first.
Mark (mhpautos)
Nov 8, 2008 at 7:32 PM
