1999 Nissan Maxima Engine stalls
SKHUARD
  • 1999 NISSAN MAXIMA
Engine Performance problem
1999 Nissan Maxima 6 cyl Two Wheel Drive 85,000 miles
Car stalls after driving for awhile, usually when coming to a stop light or slowing down. Studders when going uphill sometimes. Changed the spark plugs.
Monday, March 22nd, 2010 AT 3:44 PM
Lack of acceleration, chugging, hesitating, bogging etc. Could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Monday, March 22nd, 2010 AT 3:54 PM
