1999 Nissan Maxima Compressor Noise
FAMOUS1
  • 1999 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 121,000 MILES
The a/c works fine. When the ac is off the compressor make a whinning almost grinding noise. When you turn it on the noise stops. It cools and works great just noisey when not on.
Tuesday, September 23rd, 2008 AT 6:51 PM
2CARPRO JACK
  • 11,533 POSTS
Couldl be aproblem with theclutch hub bearing. Try removing the belt and spinning teh clutch hub to see if it feels rough, If so you may need a new one
Wednesday, September 24th, 2008 AT 7:37 AM
FAMOUS1
Do you know if this can be replaced or do I need to get a whole new compressor
Wednesday, September 24th, 2008 AT 5:25 PM
2CARPRO JACK
  • 11,533 POSTS
Should be replaceable, but it requires special pullers to get the a/c clutch off the comp
Thursday, September 25th, 2008 AT 7:44 AM
