Does the engine have a timing belt or timing chain?
JNIXON3839
  • 1999 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 175,000 MILES
Does the nissan maxima se limited edition have a timing belt or timing chain? Also would replacing an ignition coil reduce engine noise?
Monday, August 10th, 2009 AT 6:05 PM
  • 31,937 POSTS
Hi there,
Your car has a timing belt, this should be serviced at 100,000Km intervals it is an interference engine so valve damage will occur if the belt fails, the coil replacement won't have any effect on engine noise as it is only the item that generates the ignition spark.
These engines had timing belts and timing chains.
Mark (mhpautos)
Monday, August 10th, 2009 AT 6:50 PM
