If you are asking about the front outer timing cover seal all I can say is good luck on a 95 it required dropping the exhaust the lower engine mounts then the lower oil pan the upper oil pan then replacing lower mounts then removing the harmonic balancer then the cam position sensor the power steering pump the alternator the air conditioner compressor and mounting bracket the idler pulley and bracket the side motor mount then the outer timing cover comes off this took 2.5 hours in the yard with air tools and no lift average chilton time probably 10 hours at 70$ plus reinstall time about 900 $ would be a best case scenario
SPONSORED LINKS
Tuesday, April 8th, 2008 AT 10:30 PM
