1998 Nissan Maxima Car
PBREVET5
  • 1998 NISSAN MAXIMA
  • 6 CYL
  • 217,300 MILES
My 1998 Nissan Maxima SE died after driving it for about 20-30 miles when stop in traffic. I did a dagnostic and they told me that everything if fine but the car still stall after driving it for about 20-30 miles. Is it the temperature sensor or is it the compputer? Please help.
Tuesday, March 30th, 2010 AT 1:03 PM
Hi Pbrevet5, Welcome to 2carpros and TY for the donation.
When it stalls out do below immediately don't wait for nothing do it right then and there to catch it if its a fuel or spark problem something has to give.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Tuesday, March 30th, 2010 AT 6:30 PM
