Hey guys, I'm having the same exact issue. I did some research online and discovered it is the blower motor. I bought the relay for it just in case because others were having the same issue, although I couldnt find the relay on my car. I removed the glove compartment and I can see the blower motor underneath the dash on the right. I tapped on it and whal-a the ac started blowing. It worked for only a day but now when I tap on it, it just wants to give me a breeze and shut off. You can hear the motor trying to turn, but it wont blow out hard anymore. I went to Autozone to find the part, but it didnt look the same. Basically, on my motor, the end of it is visible and it extends a little downward from the motor. The one from autozone is flat. Also, I noticed the opening where the hose fits is smaller than the one on my motor. So I am out of luck. Where can I find this motor at? Also, is this an easy part to replace or will I have to take it to a technician?
Sep 8, 2008 at 2:14 PM
