1994 Nissan Maxima MASS AIR FLOW SENSOR
NOTIK
  • 1994 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 206,027 MILES
When my car is runnin it runs fine but when I stop or go at a very low mileage my car turns off but it turns back on fine. But it keeps doin it very ofthen until I stop and move the wires that are connected to the air flow sensor then it wont turn off for about 2 days and its been a month already and the check engine light turned on. Will it be good if I replace the wires that are runnin to the air flow sensor or will it be better if I replace the sensor>?
Thursday, January 17th, 2008 AT 4:51 PM
MASTERTECHTIM
  • 4,750 POSTS
Check the rubber snorkle from the mass air flow sensor to the throttle body. If there are any cracks in it you should replace that. It will cause mass air flow codes and symptoms. Hope this helps. Feedback is greatly appreciated.
Thursday, January 17th, 2008 AT 5:29 PM
