1988 Nissan Maxima V8 Automatic
The engine starts then stalls almost immediately. If you work the throttle you can keep it running, especially at higher RPM! For awhile if you disconnect the gas line off of the fuel filter outlet & then key to on position, pump will pump for approx. 5 seconds then shut off. Tried swapping out fuel pump relays to no avail. Any other suggestions on what to try or what it can be?
SPONSORED LINKS
Thursday, September 4th, 2008 AT 6:11 PM
