1988 Datsun 210 fluid clutch cylinder and clutch master cyl
110,000 MILES • 4 CYL • 2WD • MANUAL
FLUFFY123
i passed a car-shifting into another gear real fast-with the r.p.m.s kind of high-then when i went to go into another gear i had no cllutch-the pedal was hard.i had to turn the truck off ,to put it in gear and get out of the road.i maded a big mistake by changing the slave cylinder and the clutch cylinder without reading instructions-now i can:t get a pedal to come back,i bleeded and pumped pedal until i was tired and when i thought i had a little pedal-bleeded the slave cylinder and pump some more for hour:s and still nothing-what i:am i doing wrong--are is it the clutch gone.
Dec 26, 2009 at 11:25 PM
  • 75,988 POSTS
Check the clutch master cylinder could be leaking internally
Dec 27, 2009 at 7:19 AM
FLUFFY123
the clutch master cylinder is new,is not leaking floided anywhere..what do you mean by internally
Dec 27, 2009 at 9:04 AM
  • 75,988 POSTS
The clutch master cylinder functions the same way as the brake master cylinder if there's a problem witin the spool valve and seals it will not create pressure.
Dec 27, 2009 at 10:21 AM
