1998 Nissan Altima CV Clicking Noise
This is not very difficult to do, but the shaft locking nut will be very tight and beyond your means of removal and re torquing. But that aside here goes.
1 Remove large split pin at said lock nut and remove nut, Have someone stand on the brakes while you undo it.
2 Jack up and stands under chassis.
3 wheel off.
4. Remove brake calliper.
5. remove calliper mounting (two bolts)
6 If floating disc, lift off
7 Remove tie rod end nut, you will have to strike the housing where the tie rod fits to break taper, leave nut on loosely to protect thread.
8 UN do two lower strut mount bolts (two bolts holding strut to stub axle ass)
You should now be able to swing the stub assembly around and push the outer spline end out of the assembly.
The drive shaft can now be removed, it is held in place with a "C"clip so a lever will be needed to pop it out.
You will loose some oil from the transmission so be ready with a tray and make sure you have new oil to replace. You should have a drive shaft in your hands now, the fitting is reverse of removal, it is a good idea to replace the seal in the side of the transmission, but its not mandatory. use a spray on copper base lube on the splined end, this will help it seat when re torquing the drive nut, it will click in the splines if not fitted fully home. Replace all split pins with new, check and top up oil in transmission when done. use a good manual if in doubt or get a qualified mechanic to do it if you feel its a bit beyond you.
Mark (mhpautos)
Suggested Repair
Replace the passenger-side drive axle. The axle nut is very tight and hard to remove and retorque. Support the car, remove the wheel, caliper, caliper bracket, and disc if floating, separate the tie-rod end, and unbolt the strut from the knuckle so the outer spline can be pushed out. Pry the inner shaft past its C-clip, catch transmission fluid, and refill afterward. Replacing the side seal is recommended but not required; use copper anti-seize on the splines, install new split pins, and use a manual or a mechanic if the nut or procedure is beyond your tools.
Conversation Summary
The owner of a 1998 Nissan Altima with a 2.4L engine and automatic transmission hears clicking or popping from the passenger front when the wheel is turned fully and the car accelerates. They were told the CV joint is bad and asked whether special tools and a DIY procedure are needed to install a new axle. The expert said the job is manageable but the axle lock nut is extremely tight, then outlined removal of the nut, wheel, brake components, tie-rod end, and strut bolts, prying out the C-clip-retained shaft, catching and replacing transmission fluid, and reversing the steps with new split pins.
