2004 Nissan Altima
BUDDY62308
  • 2004 NISSAN ALTIMA
  • 4 CYL
  • FWD
  • 110,000 MILES
I will crank the car up, drive it for 20 min, turn it off and it wont crank back up until it cools off. What is the problem?
Wednesday, August 5th, 2009 AT 10:29 AM
STEVEW84
  • 673 POSTS
Do you mean it won't turn over or it will turn over but won't start?
Wednesday, August 5th, 2009 AT 12:14 PM
BUDDY62308
IT WILL TURN OVER FINE. BUT IT HAS TO COOL OFF BEFORE IT WILL CRANK.
Wednesday, August 5th, 2009 AT 7:55 PM
STEVEW84
  • 673 POSTS
Next time it won't start you need to see what you are missing. Like fuel pressure, spark, fuel inj. Pulse. Is your Check Engine Light on or do you have any codes?
Wednesday, August 5th, 2009 AT 9:43 PM
BUDDY62308
Everthing is working fine. Someone said it might be the crankshaft positioning sensor. What do u think?
Wednesday, August 5th, 2009 AT 11:07 PM
STEVEW84
  • 673 POSTS
Yes, crankshaft sensors have a history of failing on Nissans. Normally they will either turn the Check Engine light on and leave a code. Do you have any codes? Also, just because your Check engine light is not on does not mean you have no codes. I would check for codes first.
Thursday, August 6th, 2009 AT 7:09 AM
BUDDY62308
Cool. Doesnt autozone run the computer on it for free
Thursday, August 6th, 2009 AT 10:17 AM
STEVEW84
  • 673 POSTS
Yes, they will check to see what codes you have.
Thursday, August 6th, 2009 AT 12:22 PM
