When I start the car the, it starts and the rotations per min (rpm) goes higher than 1. Then I select the R or D on the automatic transmission the rpm falls and eventually cut off the engine. This will happen several times before I will be able to reverse and drive the car. It will run smoothly but at stops or at very low speeds it cuts off with the rpm showing just above zero.
SPONSORED LINKS
Thursday, May 20th, 2010 AT 2:25 AM
