2002 Nissan Altima P0507. Idle control system RPM higher than expected
2002 NISSAN ALTIMA
DP2680
  • 11 POSTS
2002 Nissan Altima 4 cyl Automatic 102500 miles
P0507. Idle control system RPM higher than expected what causes this to happen and what does it mean?
Dec 28, 2007 at 7:15 AM
BLACKOP555
  • 10,386 POSTS
First you should clean out your throttle body. next is your vehicle surging or just plain idling high? if its surging you should check the IAC and EGR valves. You may have a vacuum leak this guide should help.
https://www.2carpros.com/articles/engine-idles-too-high
Please go over this guide and report back.
Dec 28, 2007 at 11:49 AM
DP2680
  • 11 POSTS
I do feel like mine is surging. What is the IAC and EGR valves? What do they do and where are they located. Thank you
Dec 28, 2007 at 11:23 PM
BLACKOP555
  • 10,386 POSTS
IAC is idle air control it sets the idle for the engine, it is located on the side of the throttle body.
The EGR is exhaust gas recirucaltion, it takes the unburned exhaust gases and reburns them just like the PCV valve, it is located next to the throttle body also.
Dec 29, 2007 at 12:45 AM
LOSTINMARS
  • 222 POSTS
[quote:13f31aaf10="blackop555"]First you should clean out your throttle body.
next is your vehicle surging or just plain idling high? if its idling high turn down the idle adjust screw a tad.
if its surging you should check the IAC and EGR valves.[/quote:13f31aaf10]
cleaning the throttle is the last thing you should do on this car. this is what typically leads to this code.
the idle parameters need to be reset or the throttle body needs replaced. can only be done by someone with proper software/scan equipment to program it.
Jan 23, 2008 at 3:31 PM
