HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Altima
Engine
Symptoms
Burning Oil
2001 Nissan Altima Using oil
POCO
MEMBER
2001 NISSAN ALTIMA
4 CYL
FWD
AUTOMATIC
135,000 MILES
This engine uses 1/2 quart every fillup, does not smoak or show signs of leaking oil, where could the problem be
Wednesday, May 13th, 2009 AT 8:53 AM
MMPRINCE4000
MECHANIC
It is either leaking it or burning it.
Raise car, put on stands and inspect engine area for leaks, this is most likely possibility.
If no leaks are found, have compression test performed to rule out/in rings.
SPONSORED LINKS
Wednesday, May 13th, 2009 AT 9:04 AM
Please
login
or
register
to post a reply.
Related Engine Burning Oil Content
2001 Nissan Altima Altima Burning Excessive Amounts...
In The Past 6 Months I Have Had Cylinder Work, New Brakes (that Still Squeal), Complete Air Conditioning Service Including New Compressor...
Asked by
Never Another Nissan
1 ANSWER
2001
NISSAN ALTIMA
Excess Oil Consumption
Car Uses Alot Of Oil. And Smells From Engine When Warms Up Constantly. But, Car, Has No Signs Of, Any Leak At All.
Asked by
chrislarsen
2002
NISSAN ALTIMA
Smoke A Lot And Smell Burning Oil
I Have 2003 Nissan Altima 2, 5s Smoke A Lot And Smell Burning Oil. Check The Spark Plug All Wet Except No:3 Look Dry. Compression Tested (...
Asked by
Hend2110
1 ANSWER
2003
NISSAN ALTIMA
1996 Nissan Altima Uses Oil
We Have Given This Car A Tune Up, Including Plugs And Points, Oil Change With New Filter And Now When The Car Is Under A Load (idling Is...
Asked by
BDN10
1996
NISSAN ALTIMA
2006 Nissan Altima Oil Consumption
Engine Mechanical Problem 2006 Nissan Altima 6 Cyl Front Wheel Drive Manual 99k Miles Why Do Alot Of Nissan Engines Use Oil About A Qt...
Asked by
coachsavage2002
2006
NISSAN ALTIMA
VIEW MORE
SPONSORED LINKS
Engine Oil Change and Filter Mercedes
Ignition Coil System Test Repair - All Cars
Code Read Retrieval/Clear Chevrolet
Online car repair manuals
