2000 Nissan Altima Vibration
AMARANNA
  • 2000 NISSAN ALTIMA
2000 Nissan Altima
I have a 2000 Nissan Altima GXE - when I apply brakes the steering wheel vibrates.I changed all the 4 tires, did wheel alignment and wheel balance 3 weeks before, no change. Pls advice
Friday, October 10th, 2008 AT 5:20 PM
ZACKMAN
  • 4,202 POSTS
Have your front brake check. That vibration comes from warped rotor(s).
Saturday, October 11th, 2008 AT 4:55 AM
AMARANNA
  • 15 POSTS
I did the Brake inspection 2 times @ tires plus and they did not tell me any issues on the brakes, but instead they asked me change the struts and mounts. Pls advice.
Saturday, October 11th, 2008 AT 1:29 PM
ZACKMAN
  • 4,202 POSTS
If it is a strut/strut mount issue, you will have the vibration all the times. If it is engine/trans mount issue, you will feel the vibration at idle, and more during hard acceleration or deceleration.
But you felt it as you applied the brake. I still stand by my initial diagnosis. When was the last time that the brake system checked? I am not talking checking the pads, I mean someone actually pulls the brake rotors out, measure the disc thickness and put them on a brake lathe machine to determine warpage.
Saturday, October 11th, 2008 AT 5:19 PM
