can you tell me how to change water pump for nissan altima 2000
Jan 7, 2009 at 1:49 PM
ISLAND_PRIDE71
MEMBER
Drain coolant from radiator and cylinder block. Remove accessory drive belts. Remove lower splash shield, generator and A/C compressor. Remove radiator shroud if necessary. Remove water pump bolts and water pump.
