2000 Nissan Altima how can to change water pump
2000 NISSAN ALTIMA
97,000 MILES • 4 CYL • FWD • AUTOMATIC
KY1964275
can you tell me how to change water pump for nissan altima 2000
Jan 7, 2009 at 1:49 PM
ISLAND_PRIDE71
  • 62 POSTS
Drain coolant from radiator and cylinder block. Remove accessory drive belts. Remove lower splash shield, generator and A/C compressor. Remove radiator shroud if necessary. Remove water pump bolts and water pump.
Jan 7, 2009 at 4:19 PM
