1999 Nissan Altima Nissan Pros, thinking caps please. Rumb
BAJA318
  • 1999 NISSAN ALTIMA
  • 4 CYL
  • 120,000 MILES
I've been having a strange problem that, after three trips to my mechanic and one to the Nissan dealership, has yet to be correctly diagnosed. It just won't go away. It's happened two winters in a row and usually goes away once the weather warms up, but not this year! It's now about 70 degrees out and the symptoms are still present, just not as bad as when it was freezing outside. Here the symptoms, they all happen OCCASIONALLY - not consistently:
*Stalls when put into gear
*Rumbles and shakes when stopped at red-light
*Barely accelerates when gas pedal is first pressed, goes really slow for a few seconds and then jerks into normal speed
*Idles high when first turned on
*Idles low in reverse (or stalls as stated above)
*Occasional smell of gasoline inside the car
This same thing happened last winter, and was fixed after a few tries until THIS winter...now it's started to do it again. It seemed to stump my mechanic last year, they changed an o2 sensor, and I feel like maybe he just got lucky and the problem went away until this year. It does it most in cold weather, and usually stops after car warms up or is driven a mile or so.
I thought I had an intake manifold gasket issue, because they seem prevalent on this generation of Nissans, but the dealership said the intake manifold gaskets are perfectly fine! Ha!
Anyways, I currently have a po325 code (Knock Sensor code) on it, which both mechanics seem to have ignored. I'm really at my wits end here. Any help would be appreciated. I'm either going to have to sell this car for next to nothing and try to come up with money for a new one, or fix this issue - I'd rather fix this issue.
This is clearly not a simple or everyday problem, within the past few months I've had a full tune-up, detailed fuel injection cleaning, and have had substantial testing (diagnostics and other tests that I can't remember the names of, I know one was a bass test or something?) done at my mechanic and at the local Nissan dealership. Please don't send me an answer telling me to check my filters and such, because that's not what it is.
***Id like to add that this car is extremely well taken care of (except for that dirt you see on the dash). Ive kept up with all maintenance and have gotten pretty much all recommended work done. Im peeved!***
You can check out a video of the car during a freezing morning about a month ago here: http://www.youtube.com/watch?v=Majkr2qTXOE
Feel free to ask me any questions.
Sunday, May 3rd, 2009 AT 3:02 PM
2CARPRO JACK
  • 11,533 POSTS
Check the boot from the MAF sensor (Air cleaner box) to the engine for any signs of cracking. When put in gear the engine moves alittle and if there are any cracks that open up it leans out the engine.I have seen Nissans set knock sensor codes when they are lean (vacuum leak) check fuel pressure/volume
Monday, May 4th, 2009 AT 7:51 AM
BAJA318
  • 6 POSTS
Thanks for responding. I know that both my mechanic and the dealership did vacuum leak tests and both said there wasn't a problem. If the air cleaner box is cracked, would the vacuum leak tests account for that? Or are the two independent of each other?
Monday, May 4th, 2009 AT 10:09 AM
2CARPRO JACK
  • 11,533 POSTS
Any problem between the Mass Airflow Meter and the engine will cause a problem
Monday, May 4th, 2009 AT 3:00 PM
BAJA318
  • 6 POSTS
If there was a problem with the mass air flow meter, would a vacuum leak test find it?
Monday, May 4th, 2009 AT 4:20 PM
2CARPRO JACK
  • 11,533 POSTS
Not likely. Usually they are reading out of range and will still work, they are just off a little from what the PCM wants to see
Monday, May 4th, 2009 AT 5:04 PM
DAVE131
  • 13 POSTS
Hows you coolant or do you have water? Is it possible your throttle body is freezing up
check your coolant lines to the throttle body
more than likely not but cant hurt to look
Saturday, May 9th, 2009 AT 11:33 PM
