1998 Nissan Altima windshield wiper fluid not dispensing
1998 NISSAN ALTIMA
BABYEBK2
1998 Nissan Altima 4 cyl Two Wheel Drive Automatic
i filled the reservoir tank with windshield fluid and when i turn on the wipers to dispense the fluid no fluid comes out coud it be a realy or something else thank u for ur help
May 2, 2010 at 10:13 AM
2CARPRO JACK
  • 11,533 POSTS
Can you hear the washer motor running when you try it? If so, the squirters at the wipers are probably plugged up.The nozzles are very small and wax and other things can plug them up easily.Try removing the hose before the nozzle (under the hood) to see if it squirts there.If themotor doesnt run, you will need a test light to see what is wrong.Check fuse 19 in the under dash fuse panel. it powers the washer motor
May 2, 2010 at 1:31 PM
