If you have a P0100 code I would recommend checking the wiring to your MAF sensor first. Make sure it is fully plugged in and all the wiring looks good, no exposed wires, etc. If the wiring is good you will more than likely need a new MAF sensor. As for the ECM, I would definately question the recommendation for this especially only going off a P0100 code. Usually with ECM failures you will see many random codes for several components, because of how many components are controlled by the ECM.
SPONSORED LINKS
Saturday, January 3rd, 2009 AT 12:25 AM
