Nissan Quest Brake Pad Question
NISSAN 240SX
CMAN101
I have a Nissan Quest 2004 with 32,000 miles. I took it in for inspection. The service assistant said my brake pads are just barley passing inspection. They are not grinding and they are not making any noise. He quoted $375 for brakes and to smooth out rotors.
My question is cant they just replace the pads? If they were not grinding why would they need to work on rotors??
Mar 24, 2006 at 8:16 AM
SEVENS
  • 8 POSTS
I know from working on my own brakes that I wouldn't take the time to smooth out the rotors if they seemed "smooth enough" :) But as any brake professional will tell you, there is usually uneven wear somewhere. They can vary in thickness around the diameter from moments of brake stomping, or they could show some kind of "warpage" from heat (I've heard that, but I don't know if thats true). Anyhow, I know techs usually like to only take things apart once when it concerns the same reason, such as getting you smooth brakes, so they were probably just being safe instead of sorry. They don't like to have customers coming back with some type of squeal or shimmy after you just paid a week ago to have them installed. If you come in with a complaint, then it is there fault, and they don't get to charge you for the shave like they would have done earlier. That's my opinion.
Mar 24, 2006 at 11:35 PM
