1992 Nissan 240SX Jerks Past 2500 RPM
ONMIDNIGHTEYES
1992 nissan 240sx SE manual 83,000. the car can't idle unless you give sufficient amount of gas to keep it at a thousand rpm if you don't it sputters around 500 rpm and below, and when you start going if you hit 2500 rpm the car will start jerking and shaking until you shift. we changed the spark plugs but i think that one of the plugs aren't firing right, and there's oil leaking into one of the cylinders. what's up with it?
Dec 16, 2006 at 3:24 AM
CARUNDELL
  • 602 POSTS
[quote:e46d5ae377="onmidnighteyes"]1992 nissan 240sx SE manual 83,000. the car can't idle unless you give sufficient amount of gas to keep it at a thousand rpm if you don't it sputters around 500 rpm and below, and when you start going if you hit 2500 rpm the car will start jerking and shaking until you shift. we changed the spark plugs but i think that one of the plugs aren't firing right, and there's oil leaking into one of the cylinders. what's up with it?[/quote:e46d5ae377]
Hey eyes,
If one plug isn't firing the it may be a ign. wire or dist cap. As to the oil in the cylinder, I believe it may simply be a valve cover seal, there are seals around each spark plug hole in the valve cover (in addition to the valve cove gasket)these commonly fail and leak onto the plugs and when you remove the plug it leaks into the cylinder. Let us know!
Chris
Dec 16, 2006 at 3:51 AM
Suggested Repair
If a spark plug is not firing, inspect the ignition wire and distributor cap. Oil in a cylinder is likely from failed valve cover spark plug tube seals, and possibly the valve cover gasket, leaking onto the plugs and into the cylinder when a plug is removed.
Conversation Summary
A 1992 Nissan 240SX SE manual with 83,000 miles sputters and will not idle near 500 rpm unless held around 1,000 rpm, then jerks and shakes above 2,500 rpm until shifted. Spark plugs were replaced, and the owner suspects a misfiring plug and oil entering a cylinder. The expert suggests checking the ignition wire or distributor cap and attributes the oil to commonly failed valve cover spark plug seals.
