From empty I believe I filled up with a bad tank of gas. It quickly started running poorly. Knocking, trouble accelerating, etc... I drove it until empty and filled it with high octane fuel. It performed much better. On the next fill up I went back to the lower octante fuel to see what would happen. It now is worse than the first time. It start great, runs great while in park and neutral even when iI give it gas. When I put it in drive it goes nowhere or move very slowly. If I'm facing uphill then it doesn't move. If on level surfae or downhill it will slowly go forward at very low RPM no matter how much I step on the gas. It eventually will start to pick up speed and run normally but it takes a while. Once I come to a stop it starts all over again. It runs at really low RPM's once it goes into this weird state. Even if I put it in neutral I can't get it to increase RPM. If I turn it off and restart it then it once again runs well and responds to me stepping on the gas.
Aug 8, 2006 at 11:55 AM
