1997 Nissan 240SX Dash Cluster
1997 NISSAN 240SX
118,000 MILES • 4 CYL • 2WD • AUTOMATIC
1997NISSAN240SX
My Nissan's speedometer isn't correct it is 5 MPH faster than what i'm actually going. How can I fix that?
Mar 6, 2009 at 4:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
First have you changed tires? If tire size is different than the stock size it will throw off the speedometer. If tires are stock size then the speedo gear may be stripped or damaged or the speed sensor may be starting to fail.
Thanks for using 2CarPros.com!
Mar 6, 2009 at 5:00 PM
