no electrical
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
LITTLE-BIG-DAWG
Truck went dead have a ECM replace and now and then ignition switch and now nothing comes on. when I turn the key it's the lights overhead light will come on the door locks will operate but no power in the front really the dash panel won't light up the radio won't light up. nothing seems to be getting power when you turn the key nothing and I'm just not sure what's going on.
Jun 22, 2020 at 12:14 AM
Is this an intermittent issue that some times it works and sometimes it doesn't? I just want to make sure I understand the issue properly.
Also, when you replaced the ignition switch did this issue happen immediately after that?
Just let us know the progression and how much time was between the repairs.
Lastly, from when you said the vehicle went dead until now is there any difference in how the vehicle is acting? In other words, did the ECM and ignition switch change what the vehicle was doing?
Thanks
Jun 22, 2020 at 10:55 AM
