need to stop 19c772 from making noise when starting?
57,000 MILES • 4 CYL • 2WD • AUTOMATIC
STEVESMOLLETT
what happens if you unplug a noisy19c772 defrost panel mode door actuator. Can you access it without removing the entire dashboard just to unplug it and stop it from working? I just want to stop the noise. It only comes on when the car is cold started. once running no noise.
May 4, 2023 at 10:28 AM
