Pull over and charge system message keeps appearing?
142,839 MILES • 2WD • AUTOMATIC
JACK THAO
  • 10 POSTS
It keeps saying pull over and charge system, can I bypass this?
Aug 18, 2023 at 10:33 AM
  • 55,694 POSTS
You cannot bypass this warning; it is telling you there is something wrong with the hybrid battery. Let's do a CAN scan to confirm the issue, you can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Please go over these guides and get back to us.
Aug 19, 2023 at 3:58 AM
JACK THAO
  • 10 POSTS
I have an OBD 2 scanner, will this work?
Aug 20, 2023 at 5:26 PM
  • 55,694 POSTS
An OBD scanner is limited to some codes. The CAN scan will go into the hybrid systems and the entire car. I don't think an OBD scanner will get us the information we need if you have the scanner plug it in to see what it says.
Aug 22, 2023 at 3:17 AM
